[GRASSLIST:7240] Re: Compile Errors
Māris Nartišs maris.nartiss at gmail.com
Mon Jun 20 05:14:19 EDT 2005
hi,
some time a go I remeber problems with GRASS compiling in paralel. Try
to run "make -j1". Somtimes it helps.
Maris.
On 6/17/05, Thomas Colson <tom_colson at ncsu.edu> wrote:
> Any idea what could be causing this plethora of compile errors? Platform
> is FC4 64 Bit, gdal version is 1.2.5, fftw is 2.1.5...
>  ./configure --with-proj-includes=/usr/local/lib
> --with-tcltk-includes=/usr/local/lib --without-postgres --with-freetype
> --with-gdal --with-x --enable-largefile --enable-64bit --enable-w11
> --with-opengl-libs=/usr/X11R6/lib64
> --with-freetype-includes=/usr/include/freetype2 --with-blas --with-cxx
