[GRASSLIST:7242] Re: please lookup this bugreport
janabhaaratii at ncst.ernet.in
Mon Jun 20 14:11:53 EDT 2005
> On Tue, May 31, 2005 at 07:24:29PM +0530, janabhaaratii at ncst.ernet.in wrote:
> > Hi list,
> > I would request you to look up
> > http://www.intevation.de/rt/webrt?serial_num=3189&display=History
> > this is related to localization og GRASS to indic languages.
> > thanks
> > Swapnil Hajare
> > janabhaaratii team
> Hi,
> actually I don't fully understand the problem. GRASS 6 is able to
> render multibyte fonts also in the Tcl/TK GUI (from UTF-8
> encoded .po files).
> I have added an example here:
> http://grass.itc.it/devel/i18n.php
> -> Tcl/TK TTF Support (middle of the page)
> Screenshot:
> http://grass.itc.it/images/grass6_chinese_zh.jpg
> If it works for simple chinese, it should also do for other languages.
> But maybe I am missing the point.
> Let me propose the following: If you could translate a minimum
> (a few messages) and send us the .po file, we can insert it into
> GRASS and run some tests. Please indicate which locale/font packages
> are needed.
I have uploaded partially translated grass po files for Marathi (mr_IN) to
http://www.janabhaaratii.org.in/portal/Members/swapnil/tmp/gis/
locale: mr_IN
encoding: UTF-8
Font: http://www.janabhaaratii.org.in/janabhaaratii/src/fonts/Gargi_1.7.ttf
I have done the translations for demonstration only. They are not final.
Now will wait for your response.
bye
Swapnil Hajare
> Best regards
> Markus
This mail is sent through IMP: http://horde.org/imp/
Used as the Webmail Interface at C-DAC, Mumbai: http://www.ncst.ernet.in
