[GRASSLIST:7268] Re: db.droptable
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Jun 22 00:23:19 EDT 2005
On Tue, June 21, 2005 20:13, Massimiliano Cannata said:
> I think that's because SELECT is for access the date while EXECUTE is
> for manage the data.
> So if you want to delete, update or insert some data db.execute is the
> right command,
> while for extract and query the data db.select is the right one.
+ db.execute is for the "power" user, i.e. the one who is willing to learn
some SQL. The other commands are just frontends to db.execute to make life
easier for those that need a little help.
Moritz
> Cheers,
> Maxi
> David Finlayson wrote:
>>I have been learning the GRASS SQL commands and don't fully understand
>>why there are individual commands for some SQL statements and not
>>others (for example why not just have db.execute?). In fact, I have
>>found some SELECT statements don't work in db.execute but do work in
>>db.select. This seems a bit confusing to me.
>>David
>>On 6/21/05, Moritz Lennert <mlennert at club.worldonline.be> wrote:
>>>On Tue, June 21, 2005 18:40, Aldo Clerici said:
>>>>Dear GRASSusers,
>>>>does it exist the db.droptable command?
>>>>It is described in the GRASS GIS Reference Manual and in many tutorials,
>>>> but
>>>>it seems not to exist in my GRASS version (6.1.cvs).
>>>Currently it does not exist. The recommended way of dropping a table is:
>>>echo "DROP TABLE fmacopy" | db.execute
>>>However, it wouldn't be too difficult to create a db.droptable if there is
>>>real demand.
>>>Moritz
> Eng. Massimiliano Cannata
> Scuola Universitaria Professionale della Svizzera Italiana
> Istituto Scienze della Terra
> Via Trevano, c.p. 72
> CH-6952 Canobbio-Lugano
> Tel: +41 (0)58 666 62 18
> Fax +41 (0)58 666 62 09
