[GRASSLIST:7271] Re: Making ellipse polygons...
    Hamish
    hamish_nospam at yahoo.com
    Wed Jun 22 02:29:32 EDT 2005
> I was wondering if anyone knows of a way to make a set of evenly
> spaced, equal sized ellipse polygons of a given semimajor and
> semiminor axis.  Is there an add-on for grass that might have this
> functionality?
Geo-referenced or just on the display?
Generate the verticies in Matlab (or Octave, or whatever), save to a
file, then--
On the display:  (after some formatting in the text file)
  d.graph or d.mapgraph
As a vector:
  import directly into GRASS with v.in.mapgen from CVS or
 "v.in.ascii format=standard -n" with some formatting to add "L ?" headings.
e.g., an ellipse centered on 0,0,0 with maj-axis=1 and minor-axis=2 and
twenty subdivisions.
% matlab commands
[X,Y,Z] = ellipsoid(0,0,0, 1,2,0, 20);
x = X(2,:)';
y = Y(2,:)';
data= [nan nan; x y; nan nan];   % nan's added for 'v.in.mapgen -f'
save ellips_pts.txt data -ASCII
# back in GRASS 6.1-cvs
#  (or just copy the v.in.mapgen script in to 6.0.0)
v.in.mapgen -f in=ellips_pts.txt out=test_ellips
g.region vect=test_ellips
d.vect test_ellips
# if you want to make them filled areas instead of lines:
v.type in=test_ellips out=test_ellipsBnd type=line,boundary
v.category option=add in=test_ellipsBnd out=test_ellipsArea
It would be interesting to make the 3rd axis something and try out the new
support for 3d vectors in NVIZ .....
Hamish
