[GRASSLIST:7289] 6.1: command history not written correctly
    Thomas Colson
    tom_colson at ncsu.edu
    Thu Jun 23 12:30:57 EDT 2005
using v.in.ascii to import x,y,z points. Notice how the v.info does not
reveal the use of the "fs" option. While not a critical error, this does
prevent the use of scripting based on previous command history....
Or is this standard for the history output?
GRASS 6.1.cvs (nc):~ > v.in.ascii -z
input="/dls/NC_flood/10K_DEM_Export/Delivery/PntsBlin/Neuse/BE3720269400WC20020830.txt"
output="points_2694" format="point" fs=, skip=0 x=1 y=2 z=3 cat=0
Maximum input row length: 34
Maximum number of columns: 3
Minimum number of columns: 3
Building topology ...
310738 primitives registered
Building areas:  100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids:  100%
Topology was built.
Number of nodes     :   310738
Number of primitives:   310738
Number of points    :   310738
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
GRASS 6.1.cvs (nc):~ > v.info map=points_2694 layer=1 -h
COMMAND: v.in.ascii -z
output="points_2694" format="point" skip=0 x=1 y=2 z=3 cat=0
GISDBASE: /dls
LOCATION: nc MAPSET: PERMANENT USER: root DATE: Thu Jun 23 12:24:27 2005
Thomas Colson
Center For Earth Observation
North Carolina State University
Raleigh, NC
(919)515 3434
(919)673 8023
