[GRASSLIST:7332] Re: can't start GRASS 6.1 CVS (error in d.m)
Hamish
hamish_nospam at yahoo.com
Mon Jun 27 23:03:14 EDT 2005
[cc grasslist]
> Nope.
> when I hit "esc-enter", I get "goodbye from GRASS-GIS".....
> maybe I should get the next CVS and see what happens?
> > > > > Hello all, I've just made a fresh install of GRASS 6.1 cvs,
> > > > > but when I try to start it I get this error msg:
> > > > > >guano at Valhalla:~$ Error in startup script: ERROR:
> > > > > >LOCATION_NAME
> > > > try removing ~/.grassrc6
> > > I did it, but still the same error.
> > can you start with 'grass -text' then start the GUI with "d.m"?
> Nope.
dumb question: does your location exist and is the mapset valid?
can you edit $GISBASE/etc/Init.sh and comment out the two "tput clear"
lines by adding a '#' to the start of line? That will stop the clearing
of the screen so if there is an error message you can see it.
$GISBASE is source/dist.i686-pc-linux-gnu/ or where you installed GRASS.
I don't think that would help unless you are using a very old copy.
Hamish
