[GRASSLIST:7358] Re: can't start GRASS 6.1 CVS (error in d.m)
Hamish
hamish_nospam at yahoo.com
Wed Jun 29 02:03:54 EDT 2005
> > can you edit $GISBASE/etc/Init.sh and comment out the two "tput clear"
> > lines by adding a '#' to the start of line? That will stop the clearing
> > of the screen so if there is an error message you can see it.
> So i did, still nothing.. here goes the output...
> All myy locations and mapsets are valid (I was using then a week
> ago!), I even tried to create a new location, but got the same
> result...
> Carlos
> Welcome to GRASS 6.1.cvs (2005)
> GRASS homepage: http://grass.itc.it/
> This version running thru: shell ()
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> Start the graphical user interface with: d.m &
> When ready to quit enter: exit
> : Command not found
> Closing monitors.....
> Cleaning up temporary files.....
> done
> Goodbye from GRASS GIS
Ok. Two clues there:
and
> : Command not found
** Do you have $SHELL set to anything?
in Init.sh it does this:
sh=`basename "$SHELL"`
echo "This version running thru: $shellname ($SHELL)"
echo "When ready to quit enter: exit"
case "$sh" in
csh|tcsh)
# do stuff
bash)
# do stuff
cygwin)
# do stuff
*) #otherwise
# do stuff
"$ETC/run" "$SHELL"
esac
echo "Closing monitors....."
If $SHELL doesn't exist, then there's nothing to run in the $ETC/run
step.
I reckon that's it. try this before starting grass:
export SHELL=bash
You'll get this error in any version of GRASS from the last 5 years.
Hamish
