[GRASSLIST:6007] newbie question - vector's displaying poly's in different colours
    Pete Lancashire
    list at pdxeng.com
    Sat Mar  5 15:04:33 EST 2005
Grass6
Where can I find a turorial/HOWTO/Examples ?
Data
v.info map=wind_ca layer=1 -c
Displaying column type for database connection of layer 1:
INTEGER|cat
INTEGER|ID
INTEGER|GRIDCODE
v.db.select wind_ca
cat|ID|GRIDCODE
1|1|2
2|2|2
3|3|2
4|4|4
5|5|5
6|6|2
7|7|3
8|8|4
9|9|3
10|10|2
The data is all polygons, with GRIDCODE ranging from 0 to 10.
What I want to do is display each polygon in a unique colour
dependent on GRIDCODE. For example
GRIDCODE  COLOUR
0         white
1         blue
2         green
and so on
The other is just display the area that are only of a particular
GRIDCODE or range of GRIDCODE.
Thank you
-pete
