[GRASSLIST:6011] HOW: d.vect -a display=shape and line color changing or do not
display
Pete Lancashire
list at pdxeng.com
Sat Mar 5 16:52:25 EST 2005
When using at database with the RGB field
and doing
d.vect -a
how do i get the area line color to be the same as the area ?
or
how do i supress the line around the area ?
thank you
Steps so far
echo "alter table wind_ca add column grassrgb varchar(11)" | db.execute
echo "update wind_ca set grassrgb='222:184:135' where GRIDCODE=2" |
db.execute
--repeated as needed---
d.vect -a map=wind_ca type=area display=shape
how do i suppress the displaying of the line around each polygon/shape ?
