[GRASSLIST:6030] Re: How deep is a region?
Radim Blazek
blazek at itc.it
Mon Mar 7 03:39:52 EST 2005
How was the region file created - what was the last module which
modified the region?
Radim
David Adam wrote:
> Hamish wrote:
>>> I'm trying to set up a region, starting with a Landsat TIFF
>>> image from California. I have imported the region with r.in.gdal,
>>> which produces a large file. I then close grass60 and reopen in the
>>> new location, at which point I get the errors
>>> GRASS_INFO_ERROR(5579,1): default region is invalid
>>> GRASS_INFO_ERROR(5579,1): line 15: <depths: -1074916636>
>>> The relevant file for the region is
>>> DEFAULT_WIND --
>>> proj: 99
>>> zone: 0
>>> north: 213720.89780907
>>> south: -6149.10219093
>>> east: -168613.96484194
>>> west: -404623.96484194
>>> cols: 7867
>>> rows: 7329
>>> e-w resol: 30
>>> n-s resol: 30
>>> top: 1
>>> bottom: 0
>>> cols3: 7867
>>> rows3: 7329
>>> depths: -1074916636
>>> e-w resol3: 30
>>> n-s resol3: 30
>>> t-b resol: 1
>>> Most of the fields in the file are explained in the REGION section
>>> of the manual, but I can't seem to find anyplace that defines or
>>> explains what the "depths" field is about. But until I can get
>>> grass to accept the region, I can't do much of anything.
>>> All help is much appreciated...
>> rows,cols, and res=30 all look right. I don't know what is causing the
>> depths to go nuts. Try editing the "WIND" file in your mapset to make
>> depths: 1?
>> maybe this works as a temporary workaround--
>> try viewing the GeoTIFF meta-data with "gdalinfo".
>> If the meta-data is bogus, wipe it clean with:
>> tifftopnm map.tiff | pnmtotiff > map_clean.tiff
>> This will wipe all geo-coding, but you should be able to load into a X,Y
>> location ok and at least view the data. May rectify from there.
>> Hamish
> Thanks, I'll give that a try.
> In response to another reply, this is happening under Grass6.0.0beta2.
> But one of my questions still stands: What does depth represent? The
> other terms in the
> DEFAULT_WIND file are defined in the g.region documentation, but not
> depth. If I knew
> what it stands for, perhaps I could guess the right value.
> Thanks for the help!
> david
