[GRASSLIST:6054] RE: Grass - Redhat
RAVI KUMAR
ravivundavalli at yahoo.com
Tue Mar 8 01:28:47 EST 2005
Christian Ferreira,
1. U mean i test the rpms OF mandrake in redhat ?
with rpm -Uvh --test libproj0*.*.rpm etc, for each rpm ?
ARE THERE NO SEPERATE RPMs FOR REDHAT
2. I have loaded PCQLINUX-2005, a redhat version.
3. Then may be I have to use 'ln' also.
THOSE WITH GRASS WORKING ON REDHAT PLEASE ADVISE
the way they have loaded rpms, and possibly used 'ln' to change rpms name etc..
ThankQ in advance pl
Ravi
Christian Ferreira <christian.grass at gmail.com> wrote:
Ravi,
In addition to what Craig said, I suggest to you that also test
packages from Fedora (the free version of Red Hat now). Because Red
Hat is now based on Fedora. It's basically the same thing. Fedora is a
experimental ground for features that Red Hat is planning for its
commercial/enterprise versions of Linux.
Cheers.
Christian S. Ferreira
On Mon, 07 Mar 2005 09:32:18 -0700, Craig Aumann wrote:
> I just used the Mandrake ones. When installing, I first used
> rpm -Uvh --test libproj0*.*.rpm etc...
> to make sure there aren't any problems.
> I personally don't know why these don't exist for RedHat, as there are a
> lot more RedHat users than Mandrake generally.
> Cheers!
> Craig
> Sun, 2005-03-06 at 21:59, RAVI KUMAR wrote:
> > Craig
> > thanQ for the info. Pl let me know where I can find
> > the RPMs for redhat. I tried on RPMfind.net but for
> > redhat it drew a blank.
> > Pl let me know the website where I can down load the
> > following rpms for REDHAT (listed below which are for
> > mandrake found on RPMfind.net).
> > libproj0-4.4.8-1mdk.i586.rpm
> > xterm-196-1mdk.i586.rpm
> > libgrass5_0-1.0.0-1mdk.i586.rpm
> > libgdal0-1.1.9-2mdk.i586.rpm
> > libgdal1-1.2.2-1mdk.i586.rpm
> > libfftw2-2.1.5-3mdk.i586.rpm
> > libogdi-3.1.2-1mdk.i586.rpm
> > libgeotiff1-1.2.2-2mdk.i586.rpm
> > libstdc++6-3.4.1-4mdk.i586.rpm
> > tk-8.3.3-74asp.i386.rpm
> > tcl-8.3.3-74.i386.rpm
> > Ravi
> > --- Craig Aumann wrote:
> > > I actually use RedHat WS 3.0 and Grass 6.0. I had
> > > greater success
> > > installing 6.0 from the Development Binaries than
> > > trying to use the RPM
> > > packages (see the bottom of the download page). You
> > > should be able to
> > > find the any required packages listed to run the
> > > binary on rpmfind.net.
> > > Hope that helps.
> > __________________________________
> > Celebrate Yahoo!'s 10th Birthday!
> > Yahoo! Netrospective: 100 Moments of the Web
> > http://birthday.yahoo.com/netrospective/
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050307/e5efe4b6/attachment.html
