[GRASSLIST:6059] Re: moving layers from one machine to another
    Radim Blazek
    blazek at itc.it
    Tue Mar  8 02:25:21 EST 2005
Chris Fonnesbeck wrote:
>>>>Chris, could you try to convert head and dbln files from UNIX to Mac
>>>>(newline characters)?
>>>Radim, I changed the line endings to Mac, but I still received a bus
>>>error on loading the layer.
>>>I also updated and rebuilt from cvs this afternoon, with the same result.
>>Does the error appeares with all vectors?
>>The vectors mooved from Mac to Linux work?
> I have never successfully imported this particular vector into Mac, as
> it takes way too long (see previous thread). I just tried moving a
> simple vector layer to Linux from Mac and got a segmentation fault.
>>Can you send here the end of debug (g.gisenv set=DEBUG=5 before module)?
> Here are the last several lines
> D3/5: dig_node_alloc_line(): add = 1
> D3/5: dig_Rd_P_node()
> D3/5: dig_Rd_P_line()
> D5/5:     line type  4 -> 8
> D5/5:     line type  -1 -> 0
> Bus error
Can you try to run v.category type=point on the vector on Linux and then
copy the result to Mac if it works? The problem could be dead line, but
I don't know why. Thanks.
Radim
