[GRASSLIST:6062] Re: How deep is a region?
    Roger Bivand
    Roger.Bivand at nhh.no
    Tue Mar  8 03:24:06 EST 2005
On Tue, 8 Mar 2005, Radim Blazek wrote:
> Roger Bivand wrote:
> > On Mon, 7 Mar 2005, Radim Blazek wrote:
> >>I see, r.in.gdal was fixed after beta2, should be ok in cvs, just edit
> >>the DEFAULT_WIND and change depths to 1.
> > Reading the CVS shows include/gis.h struct Cell_head has int depths, the
> > changes in raster/r.in.gdal/main.c are setting cellhd.depths = 1.5; - why
> > should this work? And why 1.5 when the top is 1.0, bottom 0.0, and
> > resolution 1.0, all doubles? Shouldn't it just be (int) 1?
> cellhd.depths should be inited to 1, Cho followed gis/adj_cellhd.c
> where
> cellhd->depths =
>   (cellhd->top - cellhd->bottom + cellhd->tb_res/2.0) / cellhd->tb_res;
> I don't know why cellhd->tb_res/2.0, it is copy-paste of cols/rows.
Nor do I - I've added Cho to the CCs here in case GRASSLIST isn't enough.
Who else could fix and check this before tomorrow, someone who knows and
uses r.in.gdal?
Roger
> Radim
> > Roger
> >>Radim
> >>dpadam wrote:
> >>>It was created using r.in.gdal; I haven't been able to do anything further
> >>>because of the "invalid region" errors.
> >>>david
> >>>---------- Original Message -----------
> >>>From: Radim Blazek <blazek at itc.it>
> >>>To: David Adam <david at quercus.org>
> >>>Cc: grasslist at baylor.edu
> >>>Sent: Mon, 07 Mar 2005 09:39:52 +0100
> >>>Subject: Re: [GRASSLIST:6019] Re: How deep is a region?
> >>>>How was the region file created - what was the last module which
> >>>>modified the region?
> >>>>Radim
> >>>>David Adam wrote:
> >>>>>Hamish wrote:
> >>>>>>>I'm trying to set up a region, starting with a Landsat TIFF
> >>>>>>>image from California.  I have imported the region with r.in.gdal,
> >>>>>>>which produces a large file. I then close grass60 and reopen in the
> >>>>>>>new location, at which point I get the errors
> >>>>>>>GRASS_INFO_ERROR(5579,1): default region is invalid
> >>>>>>>GRASS_INFO_ERROR(5579,1): line 15: <depths:     -1074916636>
> >>>>>>>The relevant file for the region is
> >>>>>>>DEFAULT_WIND --
> >>>>>>>proj:       99
> >>>>>>>zone:       0
> >>>>>>>north:      213720.89780907
> >>>>>>>south:      -6149.10219093
> >>>>>>>east:       -168613.96484194
> >>>>>>>west:       -404623.96484194
> >>>>>>>cols:       7867
> >>>>>>>rows:       7329
> >>>>>>>e-w resol:  30
> >>>>>>>n-s resol:  30
> >>>>>>>top:        1
> >>>>>>>bottom:     0
> >>>>>>>cols3:      7867
> >>>>>>>rows3:      7329
> >>>>>>>depths:     -1074916636
> >>>>>>>e-w resol3: 30
> >>>>>>>n-s resol3: 30
> >>>>>>>t-b resol:  1
> >>>>>>>Most of the fields in the file are explained in the REGION section
> >>>>>>>of the manual, but I can't seem to find anyplace that defines or
> >>>>>>>explains what the "depths" field is about.  But until I can get
> >>>>>>>grass to accept the region, I can't do much of anything.
> >>>>>>>All help is much appreciated...
> >>>>>>rows,cols, and res=30 all look right. I don't know what is causing the
> >>>>>>depths to go nuts. Try editing the "WIND" file in your mapset to make
> >>>>>>depths: 1?
> >>>>>>maybe this works as a temporary workaround--
> >>>>>>try viewing the GeoTIFF meta-data with "gdalinfo".
> >>>>>>If the meta-data is bogus, wipe it clean with:
> >>>>>>tifftopnm map.tiff | pnmtotiff > map_clean.tiff
> >>>>>>This will wipe all geo-coding, but you should be able to load into a X,Y
> >>>>>>location ok and at least view the data. May rectify from there.
> >>>>>>Hamish
> >>>>>Thanks, I'll give that a try.
> >>>>>In response to another reply, this is happening under Grass6.0.0beta2.
> >>>>>But one of my questions still stands: What does depth represent?  The
> >>>>>other terms in the
> >>>>>DEFAULT_WIND file are defined in the g.region documentation, but not
> >>>>>depth.  If I knew
> >>>>>what it stands for, perhaps I could guess the right value.
> >>>>>Thanks for the help!
> >>>>>david
> >>>------- End of Original Message -------
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
