[GRASSLIST:6067] RE: r.mask & r.reclass en 5.7
ncandade at mail.usf.edu
Tue Mar 8 10:35:41 EST 2005
w/ regards to r.reclass, have you tried this:
r.reclass input_map output_map < rules.txt
(just specify your rules eg: 1 thru 10 = 1, and so on in a text file)
hope this helps.
> Hi Chiara,
> As I know in 6.0 it's only necesary to rename the raster file you want
> to be the mask with the name "MASK"
> I can't help you with the second questions as r.reclass works fine for
> me on 6.0 or 5.4(I'm not using 5.7)
> Hope this helps,
> hi all!!!
> I'm having just some troubles with grass 5.7 in these days....... now I
> can't find the command r.mask, has it been substitute by other command?
> another thing... we've tried to work con r.reclass, but it seems it
> doesn't work.... when the windows opens, it asks for the name of the
> raster map to be reclassified, the name of the resultant map and the
> title and no more. so when we say "run" logically the comand answers...
> "no rules especified" the question is: where have we to specify the
> rules???????????
> thanks in advance,
> Chiara
> __________________________________________________________________
> Tiscali Adsl 3 Mega Flat con 3 MESI GRATIS!
> Con Tiscali Adsl 3 Mega Flat navighi con la supervelocita'
> a soli 29.95 euro al mese, senza limiti di tempo. E se attivi entro il
> 15 Marzo, 3 MESI sono GRATIS! Scopri come su
> http://abbonati.tiscali.it/adsl/
