[GRASSLIST:6120] Access to PERMANENT folder
Paul Shapley
p.shapley at fsmail.net
Fri Mar 11 03:35:33 EST 2005
I'm having a problem accessing the PERMANENT folder in 'bash' (Grass 6.0cvs, cygwin setup.exe version 2.457.2.2). When i set up the location and mapset in bash and then press <esc><enter> i get the following error:
Sorry, no access to <<PERMANENT>>
Mapsets in location <spearfish>
PERMANENT User1
Note: you do not have access to any of these mapsets
I'm not sure what is causing this
Whatever you Wanadoo:
http://www.wanadoo.co.uk/time/
This email has been checked for most known viruses - find out more at: http://www.wanadoo.co.uk/help/id/7098.htm
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050311/940836a5/attachment.html
