[GRASSLIST:6141] Data Set to promote GRASS
    Hardeep Singh Rai
    hardeep at eml.cc
    Sun Mar 13 02:10:02 EST 2005
I wish to promote and Introduce GRASS to Students of Engineering Collge.
So looking for good presentation on GRASS. Please let me know any good
source for that.
For the same objective, I tried following data sets.
> SPEARFISH for GRASS 5.7
It appers to be working fine, but there is script in this data which may
show full potential od GRASS and this data set.
> Fire simulation data set
There appears to be good script. But on GRASS-Beta2, it gave
"segmentation fault".
> ./firedemo.sh: line 22:  1398 Segmentation fault
See below signature detail of "log".
I am using it on Debian. Is there problem with GRASS-Beta2 or with
dataset?
Can you suggest any other good dataset or how to remove this
"segmanttation fault"? Or other link to good promotional material.
H.S.Rai
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
Prepare for simulation:
REMOVE [my_ros.max]
 raster
 header
 category
 color    MISSING
 history
 misc
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_ros.base]
 raster
 header
 category
 color    MISSING
 history
 misc
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_ros.maxdir]
 raster
 header
 category
 color    MISSING
 history
 misc
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_ros.spotdist]
 raster
 header
 category
 color    MISSING
 history
 misc
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_spread]
 raster   MISSING
 header   MISSING
 category MISSING
 color    MISSING
 history  MISSING
 misc     MISSING
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_spread.x]
 raster   MISSING
 header   MISSING
 category MISSING
 color    MISSING
 history  MISSING
 misc     MISSING
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_spread.y]
 raster   MISSING
 header   MISSING
 category MISSING
 color    MISSING
 history  MISSING
 misc     MISSING
 fcell    MISSING
 g3dcell  MISSING
REMOVE [my_path]
 raster   MISSING
 header   MISSING
 category MISSING
 color    MISSING
 history  MISSING
 misc     MISSING
 fcell    MISSING
 g3dcell  MISSING
Calculate the ROS (rate of spread), etc.:
Percent Completed ...  100%
Spread:
 100%
./firedemo.sh: line 22:  1398 Segmentation fault      r.spread -ds
max=my_ros.max base=my_ros.base dir=my_ros.maxdir
spot_dist=my_ros.spotdist
w_speed=wind_speed f_mois=1hour_moisture start=fire_origin lag=95
backdrop=image_burned output=my_spread x_output=my_spread.x
y_output=my_spread.y
Spread done.
Find some fire paths:
Thanks for your interest!
Sorry, <nsites> is not a valid parameter
ERROR: Required parameter <n> not set:
    (The number of points to allocate).
Description:
 Creates a raster map layer and vector point map containing randomly
 located
sites.
Usage:
 r.random [-qzi] input=name n=number[%] [raster_output=name]
   [vector_output=name]
Flags:
  -q   Run quietly
  -z   Generate sites for category zero also
  -i   Report information about input raster and exit
Parameters:
          input   Name of existing raster map
              n   The number of points to allocate
  raster_output   Name of the output raster map
  vector_output   Name of the output vector points map
ERROR: my_spread.y - not found
 100%
ERROR: Raster map [my_path] not available
Simulation done. Thanks for your interest!
