[GRASSLIST:6158] AW: Newbie with SRTM import problem
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Mon Mar 14 11:33:45 EST 2005
Hi Karl,
try to copy the hgt.zip file into /tmp before you import it, may be the
import -script has aproblem with the cygdrive-paths.
Does this work?
Marco
P.S. I always tried it from the /tmp-dir not from any dir outside of the
cygwin-directorytree. May it's a problem with the .tmp folder in your path
to hgt.zip
P.P.S. well, as author of the CygwinGRASS-CD I can tell you, that this
Version is able to import SRTM-files (former versions had a gdal-problem,
Marco Lechner
dienstlich:
Institut für Physische Geographie
Uni Freiburg
Werderring 4
79085 Freiburg
Fon 0761 / 203-3548
Mail marco.lechner at geographie.uni-freiburg.de
-----Ursprüngliche Nachricht-----
Von: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]Im
Auftrag von Karl Broich
Gesendet: Montag, 14. März 2005 17:09
An: GRASSLIST at baylor.edu
Betreff: [GRASSLIST:6157] Newbie with SRTM import problem
Hello GRASS-list member,
I downloaded and installed GRASS 6.0 for Cygwin (Version 0.2.2) on Windows
2000.
After trying to import a SRTM-tile I got the following messages from
r.in.srtm :
r.in.srtm input=/cygdrive/d/Benutzer/b61bro/data/srtm/N35E065.hgt.zip
[: ==: unknown operand
Extracting /cygdrive/d/Benutzer/b61bro/data/srtm/N35E045...
Archive: /cygdrive/d/Benutzer/b61bro/data/srtm/N35E045.hgt.zip
inflating: N35E045.hgt
Converting input file to BIL...
A datum name wgs84 (WGS_1984) was specified without transformation
parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Illegal filename. Cannot be '.' or 'NULL'
- ** illegal name **
rm: cannot lstat
`/cygdrive/d/Benutzer/b61bro/data/test/b61bro/.tmp/b6pc196/1952.0//cygdrive/
d/Benutzer/b61bro/data/srtm/N35E045.hgt.zip':
No such file or directory
rmdir: `/cygdrive/d/Benutzer/b61bro/data/test/b61bro/.tmp/b6pc196/1952.0':
Device or resource busy
ERROR: - map not found
Done: generated map
(Note: Holes in the data can be closed with 'r.fillnulls' using splines)
My location is defined in WIND as follows:
proj: 3
zone: 0
north: 36N
south: 35N
east: 46E
west: 45E
cols: 1200
rows: 1200
e-w resol: 0:00:03
n-s resol: 0:00:03
top: 1
bottom: 0
cols3: 1
rows3: 1
depths: 1
e-w resol3: 1
n-s resol3: 1
t-b resol: 1
Has anyone an idea what might be wrong ?
Thanks in advance!
Karl
Dr.-Ing. Karl BROICH Tel: +49 / (0) 89 / 6004 2478
Universität der Bundeswehr München Fax: +49 / (0) 89 / 6004 3858
Institut für Wasserwesen
Werner-Heisenberg-Weg 39
D 85577 Neubiberg
