[GRASSLIST:6207] Re: Water basin filling w Grass
Māris Nartišs
maris.nartiss at gmail.com
Fri Mar 18 04:07:34 EST 2005
tnx for idea about teraflow. I will try it. I'm newbie - so its hard
to find best tools for doing jobs :)
But second idea would not fit to my needs - I don't have any border
polylines for lakes - I need to find out possible lake locations,
maximum possible water levels and potential spill out points. All I
have is DTM and notes on some areas where possibly where lakes.
Yeah, I know it sounds crazy, but I have only some month to write
paper for my MSc ;)
Maris.
On Thu, 17 Mar 2005 17:19:38 +0100, Massimiliano Cannata
<massimiliano.cannata at supsi.ch> wrote:
> For flat areas you can give a try to r.terraflow that manage this situation
> with a different approach.
> For find the maximum heigth to have a spill maybe you have to find the
> lowest point around the border of the lake,
> just an idea (probably stupid!): you can convert the border polyline to
> raster, with r.mapcalc get the heigth of the dem in the corrispondence cell
> and then with r.stats see the lower heigth in the map.
> v.to.rast ....input=lake_border_polyline output=border
> r.mapcalc 'dem_border=if(border,dem)'
> r.stats dem_border
> Hello!
> Max
> Māris Nartišs wrote:
> Hi all, I'm doing research - a water body simulation with Grass. I
> successfully created DTM w Grass (Hooray!) and now need to do more specific
> things. I need to find maximum possible water level for lake. I have place
> where must be a lake and I need to know what water level is maximal until it
> starts to spill out. And I need to find those spill out points and levels
> (height). I know it is possible, because I saw a demo on web but w/o HOWTO.
> http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/viz/erosion.html Any help,
> ideas welcome :)
>And another question - I was following Grass tutorial (
> http://www.ing.unitn.it/~grass/docs/tutorial/english/index_en.htm ) and
> creating basins with r.watershed but on low land it produced thousands of
> small and narrow, parallel basins and result was not even close looking to
> sample shown on tutorial
> (http://www.ing.unitn.it/~grass/docs/tutorial/english/dtm4_en.htm). I
> understand, that different data give different results, but not so
> different! Or its OK and I was just confused by beautiful results shown in
> this tutorial? (See attachment.) Grass 6.0.0 b2 TNX for reading, Maris.
> _____________________________________________________
> Ing. Massimiliano Cannata
> SUPSI - Istituto Scienze della Terra
> C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
> Tel +41 (0)91 935 12 25 - Fax +41 (0)91 935 12 09
> mailto:massimiliano.cannata at supsi.ch
> http://www.ist.supsi.ch
