[GRASSLIST:6219] Re: how to compile in suse9.2
    Luis Coronado
    minquartia at gmail.com
    Sat Mar 19 19:47:09 EST 2005
Mauricio, you have to be sure that you installed the *-devel rpms on
your distro. Yast will allow you to do that really easily. If that isn't
the situation, and you already have all the packages installed, then you
will have to give the configure script the path to those
headers/libraries on your system. Good luck!
Luis
On Sat, 2005-03-19 at 20:01 -0400, Mauricio Vargas P. wrote:
> hi all,
> I'm triying to compile grass6.0.0 in suse9.2, but i have a lot
> of problems with dependencies. i.e. curses.h can't be found but
> is there... i can't compile others versions neither.
> Some one know how to do it?
> Thanks.
> Mauricio Vargas P.
> Geólogo
> MSc en Geología
> Usurio Linux # 326558 counter.li.org
