[GRASSLIST:6239] Re: GDAL install problems
Hamish
hamish_nospam at yahoo.com
Wed Mar 23 18:49:20 EST 2005
> > What's the problem building GDAL?
> > Without it GRASS is rather isolated. It's highly recommended.
> Here's the problem with GDAL. I'm building on RH Linux from the tar
> ball. configure works just fine. Make runs into a couple of problems.
> Firstly the -I paths in the makefile are incomplete. I fixed that.
when you run ./configure, you need to use absolute path names, not
relative path names. i.e. no --path=../../libs etc.
After that be sure to do 'make distclean' or whatever to clean out the
old occurances. Or even start from a fresh directory.
> Then I run into this compiler error:
> make[2]: Entering directory
> `/home/foo/Tools/Gdal/gdal-1.2.6/frmts/ogdi' /bin/sh ../../libtool
> --mode=compile g++ -Wall -O2 -I../../port -I../../gcore
> -I../../alg -I../../ogr -I../../ogr/ogrsf_frmts -I../../port -c -o
> ../o/ogdidataset.o ogdidataset.cpp
> g++ -Wall -O2 -I../../port -I../../gcore -I../../alg -I../../ogr
> -I../../ogr/ogrsf_frmts -I../../port -c ogdidataset.cpp -fPIC -DPIC
> -o ../o/.libs/ogdidataset.o
^^^^^ bad.
> In file included from /usr/include/ecs.h:353,
> from ogdidataset.cpp:95:
> /usr/include/ecs_util.h:84:22: projects.h: No such file or directory
> /usr/include/ecs_util.h:1071: syntax error before `*' token
> /usr/include/ecs_util.h:1072: syntax error before `*' token
> /usr/include/ecs_util.h:1144: syntax error before `*' token
> Looking at these lines in /usr/include/ecs_util.h I see that they're
> all pointers to this type:
> PJ *target; /* source and target projection descriptors
> Possibly I have a bad install of ecs_util.h, but I can't find "PJ"
> anywhere.
try again with above hint?
> B.t.w. While GRASS looks pretty neat, all I need it for right now is
> to convert .dlg files into ESRI shapefiles. If anyone on this list
> knows a better way to do this conversion, then we can finesse this
> whole issue.
Then you will definitely need GDAL. You can use the 'ogr2ogr' program it
makes to do the conversion without GRASS. Of course GRASS is a great
front end for GDAL/OGR and will be needed for any advanced processing. :)
OGR SDTS-DLG page:
http://www.gdal.org/ogr/drv_sdts.html
You might check out QGIS as a GDAL/OGR frontend as well.
Hamish
