[GRASSLIST:6269] Re: hdf and modis/aster
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Mon Mar 28 09:39:19 EST 2005
Here is the full output of gdalinfo. Bit long, but I think it looks
normal (I don't have a ton of experience with these files yet).
GRASS 6.1.cvs (SonoraLL):~ > gdalinfo
MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is `'
Metadata:
title=MODIS/ASTER Airborne Simulator (MASTER) Level-1B Data
ExperimentName=Baja Mexico
FlightDate=29 April 1999
FlightNumber=99-003-02
GeographicArea=Tres Virgenes, Line 17
ClockUsedToProcess=GPS Clock
DataSliceNumber=17
FlightLineNumber=26
TotalFlightLines=40
Credits=Gumley & Hubanks/design, Fitzgerald & Cleven/modify, maintain
MASDataUsersGuideSource=MAS World Wide Web site at
http://ltpwww.gsfc.nasa.gov/MAS/Home.html
VIS/NIRCountSensitivityAdjustment=No
DataVersion=Version 1.0
SoftwareVersion=Version 9.0
CalibrationVersion=Baja_4/16-5/26 ver 0.1
data_set= MASTER Baja Mexico
data_product=straight-line flight tracks
geog_flag=c
day_night_flag=d
granule_version=1
metadata_version=9a
producer_granule_id=Version 1.0 Baja_4/16-5/26 ver 0.1
data_quality=Excellent
granule_size=3.986607e+08
begin_date=19990429 214107
end_date=19990429 214403
lat_LL=27.49829
lon_LL=-112.6536
lat_UL=27.49786
lon_UL=-112.809
lat_UR=27.53468
lon_UR=-112.8115
lat_LR=27.53519
lon_LR=-112.6534
Principle_Investigator=Joann Stock (Caltech)
Other_Aircraft_Sensors=RC-30
CreationDate=24-Aug-99 00:16:00
Subdatasets:
SUBDATASET_1_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":17
SUBDATASET_1_DESC=[4378x50] BlackBody1Temperature (16-bit integer)
SUBDATASET_2_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":18
SUBDATASET_2_DESC=[4378x50] BlackBody2Temperature (16-bit integer)
SUBDATASET_3_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":19
SUBDATASET_3_DESC=[4378x50] AnalogGain (16-bit integer)
SUBDATASET_4_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":20
SUBDATASET_4_DESC=[4378x50] AnalogOffset (16-bit integer)
SUBDATASET_5_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":21
SUBDATASET_5_DESC=[4378x50] BlackBody1Counts (16-bit integer)
SUBDATASET_6_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":22
SUBDATASET_6_DESC=[4378x50] BlackBody2Counts (16-bit integer)
SUBDATASET_7_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":23
SUBDATASET_7_DESC=[4378x50] Head1Counts (16-bit integer)
SUBDATASET_8_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":24
SUBDATASET_8_DESC=[4378x50] Head2Counts (16-bit integer)
SUBDATASET_9_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":25
SUBDATASET_9_DESC=[4378x50] Therm1Temperatures (16-bit integer)
SUBDATASET_10_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":26
SUBDATASET_10_DESC=[4378x50] Therm2Temperatures (16-bit integer)
SUBDATASET_11_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":27
SUBDATASET_11_DESC=[4378x50] Therm3Temperatures (16-bit integer)
SUBDATASET_12_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":28
SUBDATASET_12_DESC=[4378x50] Therm4Temperatures (16-bit integer)
SUBDATASET_13_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":29
SUBDATASET_13_DESC=[4378x50] CalibrationSlope (32-bit floating-point)
SUBDATASET_14_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":30
SUBDATASET_14_DESC=[4378x50] CalibrationIntercept (32-bit
floating-point)
SUBDATASET_15_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":31
SUBDATASET_15_DESC=[4378x716] PixelLatitude (32-bit floating-point)
SUBDATASET_16_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":32
SUBDATASET_16_DESC=[4378x716] PixelLongitude (32-bit floating-point)
SUBDATASET_17_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":33
SUBDATASET_17_DESC=[4378x716] SensorZenithAngle (32-bit
floating-point)
SUBDATASET_18_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":34
SUBDATASET_18_DESC=[4378x716] SensorAzimuthAngle (32-bit
floating-point)
SUBDATASET_19_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":35
SUBDATASET_19_DESC=[4378x716] SolarZenithAngle (32-bit floating-point)
SUBDATASET_20_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":36
SUBDATASET_20_DESC=[4378x716] SolarAzimuthAngle (32-bit
floating-point)
SUBDATASET_21_NAME=HDF4_SDS:
UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":43
SUBDATASET_21_DESC=[4378x50x716] CalibratedData (16-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
On Mar 26, 2005, at 3:24 AM, Maciek Sieczka wrote:
> Ian
> What does gdalinfo say about your hdf4 file? I've had an issue that
> hdf4 "Aster relative DEM" was not recongnized as georeferenced in
> newer Gdal
> versions due to changes in the hdf driver. Maybe that is your case too?
> Maciek
> ----- Original Message ----- From: "Ian W. Macmillan"
> <ian_macmillan at umail.ucsb.edu>
> To: <grasslist at baylor.edu>
> Sent: Friday, March 25, 2005 11:14 PM
> Subject: [GRASSLIST:6258] hdf and modis/aster
>> Hi all, I am trying to import some MASTER data (combined MODIS and
>> ASTER) that is an hdf4 file (it should have the same exact format as
>> MODIS data). After realizing that I need to import the subdatasets
>> (which import fine into an XY location), I have run into a problem. It
>> seems that the data I want is in one subdataset, but the latitudes and
>> longitudes are in separate subdatasets. How can I import this so that
>> the data I want is actually georeferenced?
>> I tried gdal_translate on a whim (gdal_translate -of GTiff -b 1
>> subdataset myfile.tif), but I ended up with a geotiff that either
>> gives
>> me an error of "cellhd.proj = 0 (unreferenced)" or if r.in.gdal -o
>> "G_set_window(): Illegal latitude for South".
>> Anyone run into this before?
>> Thanks,
>> Ian
>> PS Using Mac 10.3.8, Grass 6.1cvs (march 22)
>> Ian MacMillan
>> Geological Sciences-UCSB
>> "insert witticism here"
