[GRASSLIST:6297] Re: California Albers and false northing
Ian MacMillan ian_macmillan at umail.ucsb.edu
Wed Mar 30 17:47:48 EST 2005
Tim, not sure if this helps, but here goes.  Whenever I use albers
equal area for California, it needs to be in nad27, which has the clark
1866 ellipsoid.  For nad83 stuff, I can't remember right now for sure,
but I think it uses the grs80 ellipsoid.  Also, everyplace that I have
seen landsat data, it comes in utm, but mebbe that is just me.  If it
helps, the only difference btwn your proj_info file and mine is that
mine specifies
datum: nad27
G'luck
-Ian
On Mar 30, 2005, at 2:30 PM, Tim De Chant wrote:
> I'm currently working on getting Landsat images for the Bay Area into
> GRASS 6.1cvs (Mac OS X) but I keep running into issues with the
> projection.  I've searched the list and came up with one solution,
> which was to manually edit the PROJ_INFO file into this:
> name: Albers Equal Area
> proj: aea
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> lat_0: 0.0000000000
> lat_1: 34.0000000000
> lat_2: 40.5000000000
> lon_0: -120.0000000000
> y_0: -4000000
> This returns an error saying the dataset PROJ_INFO doesn't match.
> Here's what the GeoTIFF contains:
> proj: aea
> datum: nad83
> a: 6378137
> es: 0.0066943800
> lat_1: 34
> lat_2: 40.5
> lat_0: 0
> lon_0: -120
> x_0: 0
> y_0: -4000000
> no_defs: defined
> I've tried modifying the PROJ_INFO file to match this to no avail.
> I've also tried to override the projection information in the dataset
> with no luck (under both variants of the PROJ_INFO file).
> Does anyone have any advice for working with California Albers?  I'm a
> new user (so thanks for bearing with me).
> Tim
> __________________________________________
> Tim De Chant
>     University of California, Berkeley
>     Environmental Science, Policy, and Management
>     137 Mulford Hall #3114
>     Berkeley, CA 94720-3114
>     (510) 643-3910
