[GRASSLIST:6307] Re: r.terraflow
Maciek Sieczka
werchowyna at epf.pl
Thu Mar 31 14:48:30 EST 2005
Maris
> if I have a C++ compiler, will configure detect it and compile with
> C++ or I have to force it with --with-cxx flag?
By now you have to specify --with-cxx explicite.
Maybe it is a good idea to autodetect if c++ is available during ./configure
and turn on the r.terraflow if so?
> Documentation for Grass 6.0 r.terraflow does not say anything about
> requirement to compile Grass with cxx support to enable terraflow.
> There should be a note about this.
Give it a wish or a bug report. Include that the info should also go to the
"INSTALL" file.
> Currently note is only in
> requirements list, but link (Installation requirements (needed
> libraries)) in download page (http://grass.itc.it/download/index.php)
> still points to 5.4 versions requirements list and there is no info
> about C++.
Mention this in the report as well.
> How often users have C compiler and no C++ compiler? Most Linux
> distros ship with both compilers (gcc and g++) or no compiler at all.
I think what Hamish meant is that if you choose the "devel tools" (or
something like this) to be installed in most distros the gcc-c++ won't be
included. It has to be installed seperatelly usually.
Maciek
