[GRASSLIST:6694] Re: Mac OS X 10.4 and GRASS 6
    Lorenzo Moretti
    lorenzo.moretti at bologna.enea.it
    Mon May  2 05:34:19 EDT 2005
Hi Tim
>Has anyone had any luck getting GRASS 6.1 to run
>under Tiger?  I've reinstalled everything
>following the upgrade (archive and install) but
>haven't been able to get the 19 April CVS binary
>working.  I can go into the .app package and
>open the startup screen (where you choose the
>location), but it fails to launch GRASS from
>there (i.e. no GRASS prompt in the shell).  Any
>tips or just wait for an update?
>Thanks.
>Tim
I have not Tiger but you test this change.
Exit from Grass and X11.
You open grass61cvs (Ctrl+Mouse clic and Show Package Contents)
Make a copy of "grass61cvs.app/Contents/Resources/Scripts/script.scpt" file.
Double clic on
file and it is opened from Script Editor
application.
You see the source of Apple Script code. At the bottom you see:
	if uscita = "uscita" then
		set the totale to unixpathgrass &
"Contents/Resources/" & grassversionreal & "/" &
grass & mode
		tell application "X11"
			activate
			if osxaqua = "1" then
				set results to do
shell script "cd ~; DISPLAY=:0.0; export DISPLAY;
PATH=$PATH:/usr/bin; export PATH; osxaqua=" &
osxaqua & "; export osxaqua; /usr/X11R6/bin/xterm
-geometry 80x30 -e " & totale & " > /dev/null
2>&1 &"
			else
				set results to do
PATH=$PATH:/usr/bin; export PATH;" &
"/usr/X11R6/bin/xterm -geometry 80x30 -e " &
totale & " > /dev/null 2>&1 &"
			end if
		end tell
		quit
	end if
end «event coVScliI»
property ASDScriptUniqueIdentifier : "script.applescript"
You add 3 rows (after the second row):
grass & mode
		tell application "Finder"
			launch application "X11"
		end tell
			activate
				set results to do
2>&1 &"
			else
				set results to do
			end if
		end tell
		quit
	end if
Save this file.
Close X11 and Grass.
Double clic on grass61cvs application and press START.
If this change is OK it's also good for grass60 application.
Bye
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050502/86ad76a9/attachment.html
