[GRASSLIST:6695] Re: Does ODBC work in Grass 6 ?
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Mon May 2 05:52:20 EDT 2005
Hi Hamish
> > A simple question:
>> If yes, which platform please...
>> OSX platform: doesn't work (dbmi: protocol error -
>> http://intevation.de/rt/webrt?serial_num=3154)
>> Now there are mysql, pg and dbf drivers but there are many other dbms
>> and ODBC is a good option. In old 5.4 ODBC worked.
>along with that, did anyone ever get GRASS 6 working with FileMaker on
>the Mac, out of the box without having to buy 3rd party plugins?
My question is if ODBC in Grass 6 works in Linux or Cygwin. Someone
in these platforms works with ODBC in GRASS 6 ?
The other question is FileMaker Pro 7. Now FileMaker Pro 7 has a
structure like a true SQL database with Tables inside the file. This
is a big step for using FMP in new fields and, more interesting,
FileMaker Pro 7 (under Mac OS X and Windows) has two free extension
to enable FMP 7 to work like ODBC source: xDBC extension for sharing
and ODBC driver. These extensions are free. In normal FMP 7 (not
Advanced Server edition) is enabled only local sharing in the same
computer.
But there is a problem to link GRASS with FileMaker Pro 7. The ODBC
driver for FMP 7 is built with iODBC (default in OS X) and Grass
works with unixODBC.
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
