[GRASSLIST:6745] dbmi protocol error / null-values
yuhuu at gmx.de yuhuu at gmx.de
Mon May 9 19:42:40 EDT 2005
any ideas what im doing wrong to get following error-message as soon as a
table containing NULL-values is queried:
"dbmi: Protocol error (invalid table/column name or unsupported column
type)"
For example:
step 1:
echo 'create table soils (cat integer, soiltype varchar(10) )' | db.execute
step 2:
echo "INSERT INTO soils (cat,soiltype) values (5,'hello')" | db.execute
step 3:
db.select sql='select* from soils'
results correctly in output:
cat|soiltype
5|hello
step 4:
echo "INSERT INTO soils (cat) values (6)" | db.execute
but now, step 5:
results with error message:
dbmi: Protocol error (invalid table/column name or unsupported column type)
I get this always when there is a NULL-value anywhere in one of the queried
columns, also in other contexts, like v.reclass, d.what.vect etc.
I suppose this also produces problems in v.digit.
I got the problem both with dbf and mysql.
grass version is "grass-6.0.cvs_src_snapshot_2005_05_07" on debian
Thanks
Jones
+++ Lassen Sie Ihren Gedanken freien Lauf... z.B. per FreeSMS +++
GMX bietet bis zu 100 FreeSMS/Monat: http://www.gmx.net/de/go/mail
