[GRASSLIST:6767] v.in.ascii troubles (Grass 6.0.0 on OSX - binaries from ASU)
Graham Watt-Gremm
sunyata at uvic.ca
Thu May 12 18:16:04 EDT 2005
Hello all,
I have been grappling with importing a simple ascii x,y,z utm coordinates
file using v.in.ascii. I have tried all delimiters (, | tab), have run a
mac2unix script on the file, and have even tried converting it to dbf and
placing it in the dbf folder (though the documentation on this is
incomplete). In each of the cases (other than dbf) I received either
v.in.ascii input=/grassdata/zone12.txt output=z12txt1 format=point x=1 y=2
z=0 cat=0
Maximum input row length: 0
Maximum number of columns: 0
Minimum number of columns: -1
x column number > minimum last column number
Or created a map but with errors and unreadable:
v.in.ascii input=/grassdata/zone12.txt output=z12txt format=standard x=1 y=2
z=0 cat=0
Error reading ascii file:
385 5437031
290562 5440684
287381 5437033
287381 5437033
283465 5438841
287370 5437037
287381 5437033
Building topology ...
Registering lines:
0 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Would love anyone's advice on this...
Graham Watt-Gremm
University of Victoria School of Enviromental Studies
Here is a sample of what I am working with
287361,5437037,1297
287325,5437040,1322
287071,5436724,1228
287071,5436724,1228
284048,5440888,1830
285884,5440914,2231
287385,5477029,1304
287385,5437040,1297
287385,5437040,1297
286928,5437230,1256
287385,5437040,1297
287385,5437040,1297
327552,5452646,1190
287371,5437043,1292
287371,5437043,1292
290202,5448299,1555
287272,5448910,1949
287371,5437043,1292
287371,5437043,1292
287371,5437043,1292
