[GRASSLIST:6768] Re: V.in.e00 and avcimport?
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Thu May 12 18:22:25 EDT 2005
Hi Jonathan
>I was hoping someone could tell me where acvimport (the executable) needs to
>be hiding in order for v.in.e00 to work? I managed to compile it for MacOS
>X but I don't know where GRASS is looking for the binary in order to use
>it...
>By the way, to compile it for MacOS X (I think this is working):
>1) Download http://avce00.maptools.org/avce00/avce00-1.2.0.tar.gz (I can't
>seem to remember where I found v. 1.2.1 -- its somewhere out there).
>Decompress it (safari/stuffit will probably do it for you).
>2) cd avce00-1.2.1
>3) ranlib avc.a
>4) make
avcimport and e00conv binary for OS X are present in the package
GRASS FOR OS X at:
http://wwwamb.bologna.enea.it/forgrass/
Install the libraries and you have all installed in /usr/local/grasslib folder.
In a previous mail I have explained how to compile this source in Mac OS X.
You can use v.in.e00 command inside Grass or if you want, use a
simple drag and drop application with name "avcimport-convert e00
file" inside "Grass/Extra" folder and you can convert an e00 file to
an Arc/Info coverage and you can use this new file with v.in.ogr
inside Grass.
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050513/30b0d8f8/attachment.html
