[GRASSLIST:6791] Re: neighbors of polygons
Daniel Isenegger
disen at geo.unizh.ch
Mon May 16 08:32:25 EDT 2005
Radim Blazek schrieb:
Hi Radim,
thanks for your quick answer, but i do net get it: neither the plan nor
the concrete commands
> Daniel Isenegger wrote:
>> Hi,
>> i work with grass 5.7 having the attribute data in postgres-DB.
>> in a polygon-shapefile containing several hundred of polygons i want
>> to analyze for each polygon which neighboring polygons it has.
>> Conceptually i see there 2 cases:
>> 1) neighboring polygons sharing a common boundary with the current
>> polygon: these polygons should be selectable by identifying the
>> identifiers of the border-lines of the current polygon and search
>> over all border-lines of all polygons for those identifiers.
>> here my question is: how to identify the identifiers of all
>> border-lines of a polygon?
> v.category layer=2 type=boundary to assign cat to boundaries
> (avaialable parameters: input, output, type, option, cat, field, step)
- v.category: does not have a parameter layer (at least in my grass 5.7)
- assigning cat to boundaries means: having for all boundaries the
associated cat (ie polygon(s)-IDs) they belong to?
> v.to.db option=sides -p
- v.to.db: parameter option does not have a value sides (only cat,
areas, length, count, coor, query)
Dani
>> 2) neighboring polygons not sharing a border with the current
>> polygon: here i thought of creating buffers with increasing sizes
>> around the current polygon and looking for
>> - easy case: centers of other polygons located within these buffers
>> - computationally more challenging case: arbitrary point of a polygon
>> here my questions: this method is not very elegant (conceptual and
>> technical). do you have better ideas for solving a problem like this
> use previous boundaries with cats as input for v.to.points
> find nearest areas for created points using v.distance
> Radim
>> Many thanks
>> dani
>> ps i tried to do an approach to do this with v.to.db, but didn't
>> progress much
