[GRASSLIST:6807] Re: cs2cs and grass
Francesco Mirabella
mirabell at unipg.it
Wed May 18 03:51:18 EDT 2005
Many thanks to Paul and Tom, now I get and error of ~4cm due to the
original data error (4 decimal places in latlong data).
cheers,
Francesco
On Tue, May 17, 2005 at 02:57:35PM -0600, Tom Russo wrote:
> On Tue, May 17, 2005 at 07:20:19PM +0100, we recorded a bogon-computron collision of the <paul-grass at stjohnspoint.co.uk> flavor, containing:
> > Francesco Mirabella wrote:
> > >Just to check,
> > >I tried to project the point from WGS84 to Gauss Boaga using cs2cs:
> > > cs2cs -E +proj=latlong +datum=WGS84 +to +proj=tmerc +lon_0=15
> > > +k=0.9996 +x_0=2520000 +ellps=intl -v -f %.6f
> > >After importing the point of check into the Gauss Boaga location, it
> > >results to be shifted about 167 m (mainly to the North) with respect to
> > >the point project (v.proj).
> > >where am I wrong? can anyone help??
> > Looks like you left +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> > out of the PROJ.4 description of the rome40 location, so the datum shift
> > will not have happened there. Probably the GRASS result is the correct one?
> Try using "g.proj -j" (print location projection in PROJ.4 format) in the
> Gauss Boaga location and using the output of that for your cs2cs ... +to
> options. Bet it'll agree better, because then you can be sure you have all
> the arguments that Grass is using.
> Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
> Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1
> "The only thing you can do easily is be wrong, and that's hardly
> worth the effort." -- Norton Juster
Francesco Mirabella,
Istituto Nazionale di Geofisica e Vulcanologia
Sismologia e Tettonofisica, Roma (Italy)
contact c/o:
Structural Geology and Geophysics
address: University of Perugia,
Dipartimento di Scienze della Terra
Piazza Universita', 1 06100 Perugia (Italy)
tel: ++39.(0)75.585 2651
fax: ++39.(0)75.585 2603
e-mail: mirabell at unipg.it
web: http://www.unipg.it/~mirabell/
