[GRASSLIST:6911] Re: struggling with v.in.ascii
Hamish
hamish_nospam at yahoo.com
Fri May 27 02:50:20 EDT 2005
> I am using GRASS on a debian/testing system, but grass compiled from
> source. s.in.ascii in grass54 is reading the file (see below) without
> problems. v.in.ascii in grass61cvs from today is checking the file and
> comes up with the right conclusions about the number of columns and
> the respective data types (see below), but is not writing anything to
> the resulting vector dataset (it contains only a database link).
don't know. Same data file works fine for me on a similar system.
Maybe try more modules that use G_tempfile() to see if the problem is
there. e.g. r.digit or r.average.
Hamish
