[GRASSLIST:6925] Re: r.out.gdal problems
    Hamish
    hamish_nospam at yahoo.com
    Fri May 27 21:24:47 EDT 2005
> > > > > was trying to export a GRASS raster with r.out.gdal and had the
> > > > > following error:
> > > > > r.out.gdal in=amox out=amox format=GTiff type=Float32
> > > > > Writing format: GTiff
> > > > > Writing type:   Float32
> > > > > Failed to process SRS definition: 'PROJCS["UTM
> > > > > I am using GRASS6.1-cvs and GDAL 1.2.6, both installed from source
> > > This happened with this morning's CVS version...
> > Yes, confirmed with Spearfish. The quoting bug still lives.
> Hmmm... ok well I was able to use r.out.gdal in the GRASS6.0 release.
Yes, there is a bug fix after 6.0 in CVS which is causing new problems.
Seems simple enough so hopefully fixed soon.
Hamish
