[GRASSLIST:6928] Re: multiple users issue
Daniel Gavin
Daniel.Gavin at uvm.edu
Fri May 27 22:22:31 EDT 2005
Thank you for this explanation. I will make a group-writeable
database directory for my project (my next chance will be in a few
days, though!).
At 12:08 AM +0100 5/28/05, Glynn Clements wrote:
>Ian W. Macmillan wrote:
>> Unfortunately you must have administrative access (root) to run grass. I
>> haven't heard of any way around this.
>That definitely isn't true.
>However, you need to ensure that directory ownership and permissions
>are correct, e.g.:
>1. A user needs to own their mapset directories; write permission
>isn't sufficient (although it isn't hard to remove this restriction if
>it's a problem).
>2. To create a new mapset within a location, a user needs write
>permission on the location directory.
>3. To create a new location, a user needs write permission on the
>database directory.
>How to achieve this depends upon how much freedom the users need.
>For a teaching environment where the users are students carrying out
>predetermined tasks with a supplied dataset, root can pre-create all
>of the mapset directories (one per user, plus PERMANENT) and set each
>user's directory to be owned by that user.
>If you need more flexibility, e.g. the users are staff, researchers or
>more advanced students, and need to be able to create new locations
>and mapsets, the database and location directories need to be at least
>group-writable so that users can create new subdirectories.
>Glynn Clements <glynn at gclements.plus.com>
Dan Gavin
Research Associate
University of Vermont
Botany and Agricultural Biochemistry
120B Marsh Life Science
109 Carrigan Dr.
Burlington, VT 05405-0086
