[GRASSLIST:8829] Re: GRASS and xgrid
James Conolly
jamesconolly at trentu.ca
Tue Nov 1 08:57:44 EST 2005
Jachym,
xgrid is a method for parallel processing, not a data format. The issue is that I'd like to run many (many) r.los (or r.cva on a large sample) - I've estimated what I need is in the region of a few months+ processing time. I've got xgrid running in my lab, but there are issues (a) with the grass shell and (b) the fact that the code for r.cva or r.los isn't parallel. I could break the job down into chunks and send it to xgrid to have it farmed out, but I'd like to know if anybody has already tried this.
Cheers, James
Trent University, Canada
>hi,
>on http://www.gdal.org/formats_list.html you can find data formats,
>supported by GDAL library (and GRASS).
>I'm affraid, xgrid is not between supported formats, try another one.
>Jachym
