Is there any way to edit the attribute tables for a vector layer if you are using the default internal GRASS db? I know that I can set the database to an external mySQL db (for example), and then use a mySQL db tool to edit the tables. Is there any way to do it for the internal GRASS db? Thanks, - Jason
