[GRASSLIST:8913] Re: distance algorithim
    Joel Pitt
    pittj2 at lincoln.ac.nz
    Mon Nov  7 05:56:42 EST 2005
 From the r.distance page:
"Locates the closest points between "objects" in two raster maps. An
"object" is defined as all the grid cells that have the same category
number, and closest means having the shortest "straight-line" distance."
Unless I give every cell a unique category r.distance isn't suitable. I
also calculate a statistics based on the distances as my module runs.
As an update - the described algorithm does work pretty fast. I hadn't
"make installed" my changes so my tweaks weren't actually being used. Doh.
Perhaps I should alter r.distance to allow for this alternative
behaviour? Does this sound useful to anyone?
Cheers,
Joel
Michael Barton wrote:
>Doesn't r.distance already do this?
>Michael
>__________________________________________
>Michael Barton, Professor of Anthropology
>School of Human Evolution and Social Change
>Arizona State University
>Tempe, AZ 85287-2402
>phone: 480-965-6213
>fax: 480-965-7671
>www: http://www.public.asu.edu/~cmbarton
>>From: Joel Peter William Pitt <joel.pitt at gmail.com>
>>Date: Mon, 7 Nov 2005 15:30:19 +1300
>>To: <grasslist at baylor.edu>
>>Subject: [GRASSLIST:8906] distance algorithim
>>Hi all,
>>I'm trying to optimise a grass module that takes two maps of a
>>phenomenon at different times. It calculates the distance between the
>>raster cells in the later map to the nearest cell in the earlier map.
>>Obviously when the earlier map has alot of cells present it takes a
>>while to find the closest.
>>Currently I'm optimising it by making a list of cell coordinates for
>>the cells in the earlier map. I only add cells to the list that are
>>not surrounded by other cells - ie I'm only adding cells from the
>>outlines of contiguous areas. Each cell present in the later map is
>>compared to the earlier map to check if the same raster cell is
>>present, if so the distance is 0.
>>I also split this list into a grid. The grid is basically a lower
>>resolution raster of the same map, but contains a list in each cell of
>>the coordinates that fall within the grid position.
>>e.g
>>Say the raster region is 100,100 and the grid spacing is 16
>>This gives a grid size of 7 rounding up from 6.25.
>>Say we have a coordinate in the later map: 34,50. This evaluates to
>>grid position (3, 4). Because 34/16 = 2.125 and 50/16=3.125, and each
>>is rounded up.
>>To find the nearest cell in the past map we compare distances to all
>>the coords associated with grid position (3,4) - we also compare the
>>distances to the 8 surrounding grid positions in case coords in one of
>>these is closer. If no coords are found then the grid positions
>>surrounding the surrounding positions are searched, etc.
>>The grid spacing has some effect on performance - and for my purposes
>>it seems like 16 does alright.
>>So, the point of this post is:
>>Is this the best way to be doing this? Does anyone know of a better
>>algorithm? I know for linear 1 dimensional data I could be using a
>>range of structures to find the closest, but for two dimensional data
>>I don't know any.
>>Alternatively, if my current method is reasonable are there any
>>additional things I could do to speed it up?
>>Note, I am doing stochastic dispersal simulations, and although this
>>does run a 25 timestep simulation within half an hour, I need to do as
>>many replications as possible. The major hold up at the moment is this
>>distance evaluation. Part of the problem is that the present cells are
>>very scattered, so only adding the boundary cells to the lists doesn't
>>have as great an impact as it usually would.
>>Any suggestions or comment appreciated, thanks!
>>Joel
