[GRASSLIST:8918] Re: points in area
Markus Neteler neteler at itc.it
Mon Nov 7 09:56:24 EST 2005
Maik Trömel wrote:
> I think my question is not clear enough.
> I know there's possibility to get points lying in an area with v.select.
> In my map i've got several areas. I need all points lying in area a to
> make a statistic with v.univar. But with v.select there is only the
> possibility to get all points lying in all areas. That's not what I need.
Simply first extract area 'a' with v.extract, then run v.select on this
new map.
For several areas it's best to write a small script which loops over the
area map,
extracts, selects, and runs v.univer.
hope this helps
Markus
