[GRASSLIST:8937] Re: freeze while digit
    Ralf Gerlich
    ralf.gerlich at bsse.biz
    Tue Nov  8 10:55:34 EST 2005
Hello,
Josip Vrlić wrote:
> Hello!
> I use Grass 6.1 with Cygwin (Windows xp) and while i'm in module
> v.digit, open monitor is often be freeze. And after I exit end enter
> again I lost everything I have been digitalize because I can't open
> cretaed map for continue digit with this message:
> Cannot open old vector mk11GraniceKopna at PERMANENT
> <mailto:mk11GraniceKopna at PERMANENT> on level 2
> Does anyone know how to resolve this problem?
You need to run
v.build map=mk11GraniceKopna
in your PERMANENT mapset. On the general issue of v.digit freezing on
Cygwin: Sorry, I can't help. I'm having this problem myself.
Hope this helps,
Ralf
