[GRASSLIST:8955] OFT: qgis - postgis
ivan marchesini marchesini at unipg.it
Wed Nov 9 07:07:31 EST 2005
Dear all,
I have installed on a pc running mandrake 10, qgis0.7.pre2 compiled with
grass 6.0.1
contemporary I have compiled PostgreSQL 8.1 and postgis1.0.4 with geos,
proj and plpsql....
I have used SPIT to import succesfully a points map into postgis...
I can see the map, I can edit the map to remove points but I can't
insert new points....
when I try to insert points qgis put the point into the map but when I
stop to digitize the result is that it can't commit changes:
parse-error invalid geometry
context: SQL function geomfromwkb statment 1
can you explain me ho can I solve this kind of problem???
or which step can I do to verify if the installation of postgis is
rigth...
thank you very much...
I have posted the problem on the qgis forum but I haven't got
answers....
Il giorno mer, 09-11-2005 alle 12:09 +0100, Ing.Peter Misovic ha
scritto:
> Hi ,
> Grass GIS for WIN is running only under CygWIN environment. It is not
> Windows executable. QGis for Windows is cimpiled as standard Windows
> executable. Result ? Native Windows executable for GRASs are not ready
> yet. Answer : It is not possible run Qgis with GRASS support on
> Windows platform.
> Peter
> On 11/9/05, Iñigo Telleria Elola <tellenaiz at hotmail.com> wrote:
> > I want to integrate Grass and qGis to use the plugins of Grass with qGis.
> > I'm trying to start qGis with grass, but I haven't achieved. So it's
> > imposible to get this in Windows?
> >  ________________________________
> > From:  Radim Blazek <radim.blazek at gmail.com>
> > To:  Iñigo Telleria Elola <tellenaiz at hotmail.com>
> > CC:  GRASSLIST at baylor.edu
> > Subject:  [GRASSLIST:8950] Re: Integration of Grass and qGis
> > Date:  Wed, 9 Nov 2005 11:46:40 +0100
> > >It's not yet possible to use QGIS + GRASS on Windows
> > >because native port of GRASS is not yet ready.
> > >It will be available soon.
> > >Radim
> > > > I have installed Grass 6.1 in Windows and now I want to integrate Grass
> > with
> > > > qGis 0.7.4. It's posible the integration? Or I have to use another
> > version
> > > > of Grass and qGis to get the integration?
> > > > Which are the steps to get the integration?
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
