[GRASSLIST:8958] Some issue with v.in.ascii and GRASS manual
Luca Casagrande
luca.casagrande at gmail.com
Wed Nov 9 10:39:21 EST 2005
Hi to all guys!
For my italian gis wiki ( http://www.freegis-wiki.it ) i am adding to the FAQ
section the question that i found on the international ML (the italian one is
not so populated ). I notice that a lot are having issue with importing txt
file as vector one, so i decided to do some resarch in this direction.
I toke this example from v.in.ascii manual:
GRASS 6.0.1 (spearfish60):~ > cat points3d.dat
593493.1|4914730.2|123.1|studna|well
591950.2|4923000.5|222.3|kadibudka|closet
589860.5|4922000.0|232.3|hruska|pear
590400.5|4922820.8|143.2|mysi dira|mouse hole
593549.3|4925500.7|442.6|mineralni pramen|mineral spring
600375.7|4925235.6|342.2|kozi stezka|goat path
and then run:
cat points3d.dat | v.in.ascii -z z=3 cat=0 out=mypoints3D \
columns='x double, y double, z double, label_cz
varchar(20), label_en varchar(20)'
But got this output:
Maximum input row length: 25
Maximum number of columns: 3
Minimum number of columns: 0
ERROR: x column number > minimum last column number
What am i missing?
Thx
Luca
GIS for GENTOO Developer
gtalk: luca.casagrande at gmail.com
skype : thedoktor78
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20051109/a21175d5/attachment.bin
