[GRASSLIST:8959] Re: make a  x, y, z map
    Tiago Salgueiro
    1010664 at isep.ipp.pt
    Wed Nov  9 13:35:16 EST 2005
Hello,
I downloaded the precompiled version for fedora core 3 in:
http://www.dirap.unipa.it/~scianna/grass_gis_6-0-0.htm
and installed it using the installation script. Can it be wrong? I mean
can libgdal.so.1 missing?
Thanks!
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
Nº1010664
> Hello Tiago,
> On Wed, 9 Nov 2005 12:59:01 -0000 (WET) "Tiago Salgueiro"
> <1010664 at isep.ipp.pt> wrote:
>> Now I create a location, I hope is created well...
>> when I try the command:
>> v.in.ascii -z input=/home/tiago/teste output=teste_out
>> format=point fs=tab skip=1 columns='x double precision, y double
>> precision, z double precision, cat int' \x=1 y=2 z=3 cat=0
>> The message I had is the following:
>> v.in.ascii: error while loading shared libraries: libgdal.so.1: cannot
>> open shared object file: No such file or directory
>> How can I solve the problem??
> it looks like your installation of gdal is somewhat faulty. Please
> check that libgdal.so.1 is existent on your filesystem and can be found
> in one of the folders listed in /etc/ld.so.conf.
> If the path to libgdal is not in there, add it and run ldconfig (as
> root) afterwards.
>  hope that helps
> 	Stephan
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
> Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
> Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
