[GRASSLIST:8997] Re: libgdal.so.1]
Hamish
hamish_nospam at yahoo.com
Thu Nov 10 18:11:14 EST 2005
> I tried to install gdal rpm but an error appears saying that gdal and
> [libgdal.so.1] are missing...
> What can I do? Thanks!
weird. rpm for your distro or from another?
http://www.gdal.org/download.html
See if something like libgdal.so exists on your disk ("locate libgdal"
might work). If it does,
cd /usr/lib
ln -s libgdal.so libgdal.so.1
(or whatever your libgdal.so is called)
This to makes a symbolic link to the real library with the name your
GRASS binary wants.
Then rerun ldconfig. Maybe cleaner to do:
ln -s /usr/lib/libgdal.so /usr/local/lib/libgdal.so.1
(make sure /usr/local/lib in is /etc/ld.so.conf)
If there is no libgdal on your system you need to make sure the GDAL
package is installed correctly.
rpm -q gdal
Hamish
