[GRASSLIST:9021] Re: Show Attributes error in d.m
Michael Barton
michael.barton at asu.edu
Fri Nov 11 20:35:32 EST 2005
David,
I just tried this with a Mac binary from 5-Nov-2005 and it seems to work
fine as long as the db connection is set correctly. You might need to update
the GIS Manager at least.
I've got a couple of updates to the GIS Manager to upload to the CVS on
Monday. One will change the show coloumns button to show the attribute
columns from the layer selected in the options panel (query layer for
d.vect). Also fixed an issue affecting display of thematic maps in the GIS
Manager.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: David Finlayson <david.p.finlayson at gmail.com>
> Date: Thu, 10 Nov 2005 15:02:09 -0800
> To: GRASSLIST <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:8996] Show Attributes error in d.m
> I was testing out the new d.m GUI from CVS (updated this morning). I
> have a vector layer connected to an attribute table in sqlite3. It
> seems to display fine from the GUI, including labeling by different
> attributes in the database. But when I click the button to show
> attribute columns I see the following error:
> v.info: error while loading shared libraries: libgrass_vect.so: cannot
> open shared object file: No such file or directory
> Dropping to the command line and trying v.info I do not get the error:
> GRASS 6.1.cvs (WASPN_NAD83):~ > v.info -c blocksall
> Displaying column types/names for database connection of layer 1:
> INTEGER|cat
> DOUBLE PRECISION|BCHLENGTH
> DOUBLE PRECISION|BCHAREA
> DOUBLE PRECISION|BCHWIDTH
> TEXT|BLOCK_ID_
> INTEGER|BLOCK_NO_
> TEXT|FOCAL_AREA
> TEXT|OLD_ID
> TEXT|INC_ANALY_
> INTEGER|N_JETTY
> INTEGER|N_LAUNCHRA
> INTEGER|N_RAILLAUN
> INTEGER|N_STAIR
> INTEGER|N_DOCK
> DOUBLE PRECISION|N_BULKLENG
> DOUBLE PRECISION|N_MARINA
> Is this a bug with the GUI or am I not triggering the call to
> libgrass_vect.so from the CLI? (I updated and recompiled CVS grass
> this morning).
> Thanks,
> David
> David Finlayson
> Marine Geology & Geophysics
> School of Oceanography
> Box 357940
> University of Washington
> Seattle, WA 98195-7940
> USA
> Office: Marine Sciences Building, Room 112
> Phone: (206) 616-9407
> Web: http://students.washington.edu/dfinlays
