[GRASSLIST:9111] Re: Create new location with shellscript
    Hamish
    hamish_nospam at yahoo.com
    Thu Nov 17 01:57:29 EST 2005
> is there a documentation about the parameters necessary for the
> diffrent projections known in GRASS.
Generally it follows PROJ4 parameters:
  http://www.remotesensing.org/proj/
  http://www.remotesensing.org/proj/gen_parms.html
> in /usr/local/grass6.0.1/etc i found the file projections but in
> PROJ_INFO the is an number for the projection.
That is class of projection, the number is not of much practical
interest to the user, but here they are anyway:
include/gis.h
#define PROJECTION_XY  0
#define PROJECTION_UTM 1
#define PROJECTION_SP  2
#define PROJECTION_LL  3
#define PROJECTION_OTHER  99
Usually you just need to run g.setproj and type "list" if you don't
know what to choose. see also g.proj.
Hamish
