[GRASSLIST:9161] Re: import shapefile with v.in.ogr and a
script , qgis
Helmut Kudrnovsky
hellik at web.de
Sun Nov 20 11:52:12 EST 2005
hola stephan,
at http://linux01.gwdg.de/~pbleser/rpm-navigation.php?cat=Libraries/sqlite/
you can only find sqlite version 3.0.8 release 1 for suse 9.2. i found
rpm´s later than sqlite-3.1.3-3 for suse 9.2 at rpmseek.net. then
installing of qgis was o.k.
greetings
helli
At 12:35 20.11.2005, Stephan Holl wrote:
>Hello Helmut,
>On Sun, 20 Nov 2005 11:52:56 +0100 Helmut Kudrnovsky <hellik at web.de>
>wrote:
> > hi grass-friends,
> > i have a lot of shape-files, which i want to import with v.in.ogr in
> > an existing location/mapset. location/mapset and shape-files have all
> > the same projection.
> > i´m not very familiar in scripting in grass/linux, but maybe a
> > "scripty" way of import would be the best way for import. are there
> > some internet-sources about examples of such scripts? where have i to
> > store the scripts?
>just write a short shell-script for batch-import
>untested:
>---script begins---
>#/bin/bash
>for i in `ls *.shp`
>do
> echo "importing shape $i..."
> v.in.ogr dsn=$i out=`echo $i|cut -d"." -f1`
>done
>---script end---
>This will most probably not work if filenames do have spaces, but right
>now I do not have a solution for that.
>Probably someone can provide a more sophisticated method of
>batch-importing.
> > a second question, maybe in the wrong list:
> > i´ve downloaded yesterday the latest rpm´s of grass and qgis for suse
> > from the gdf-homepage. they are compiled for suse 9.3, but my
> > linux-machine is running on suse 9.2.
> > the install of the most programs is o.k., but, if i want to install
> > qgis, there is the error message, that the right squlite-version is
> > missing. have i to update/upgrade my sqlite-version (version of the
> > original suse 9.2-dvd) to the next version?
>Please have a look at the SuSE-Readme:
>sqlite3 packages for several SuSE distributions <= 9.2 can be obtained
>from
>http://linux01.gwdg.de/~pbleser/rpm-navigation.php?cat=Libraries/sqlite/.
>For SuSE 9.3 sqlite-3.1.3-3 is included.
>This should work then.
> > with greetings from tyrol an thanks in advance
>Best
> Stephan
>GDF Hannover - Solutions for spatial data analysis and remote sensing
>Hannover Office - Mengendamm 16d - D-30177 Hannover
>Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
>Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
