[GRASSLIST:9165] Re: grass.itc.it
Māris Nartišs
maris.nartiss at gmail.com
Mon Nov 21 05:07:57 EST 2005
sems that problems with grass.itc.it now are gone. Worksforme :)
Maris.
2005/11/20, Maciek Sieczka <werchowyna at epf.pl>:
> Hi,
> On nie, 2005-11-20 at 14:59 +0100, Markus Neteler wrote:
> > On Fri, Nov 18, 2005 at 08:20:51PM +0100, Roger Bivand wrote:
> > > On Fri, 18 Nov 2005, Trevor Wiens wrote:
> > > > Now it is working, when I ran tracepath yesterday the system seemed to get caught in some
> > > > weird loop at an Italian internet provider. Some sort of endless loop between two machines there.
> > > > I found I could access via an internet proxy though. My guess is the provider in question
> > > > had their routing messed up.
> > > > I wonder if other people have had their access problems resolved too.
> > > Seems to be resolved through the proxy, yes.
> > I am not aware of any changes here, the server is/was untouched.
> > In any case consider to put me in CC, to get notified
> > immediately ... I didn't receive mails from Baylor for a couple
> > of days (maybe due to the same problem). Since today messages
> > arrive again from this list.
> Markus,
> I haven't got any problems accessing grass.itc.it ever. But I've had
> problems with grasslist recently - at 17:00 (Poland) Wed 16.11.2005 I
> couldn't post to grasslist being rejected for "Only list subscribers may
> send messages to this list." while being subscribed AAMOF. Tried several
> times after to noavail and finally re-subscribed which fixed the
> problem. Thought you might like to know as you mentioned your grasslist
> issue.
> Here's the header of my rejected message if it helps to explain
> anything:
> Dear werchowyna at epf.pl:
> Your recent message to the GRASSLIST list has been
> rejected for the following reason:
> Only list subscribers may send messages to this list.
> If you need assistance, please contact the list owner at
> GRASSLIST-request at baylor.edu
> The text of your message follows:
> Received: from fs-exchange1.baylor.edu (sisko.baylor.edu [129.62.3.211])
> by ccis01.baylor.edu (8.9.3p2/8.9.1) with ESMTP id KAA1413147
> for <GRASSLIST at listproc.baylor.edu>; Wed, 16 Nov 2005 10:07:23
> -0600 (CST)
> Received: from waylon.baylor.edu ([129.62.3.228]) by
> fs-exchange1.baylor.edu with Microsoft SMTPSVC(6.0.3790.211);
> Wed, 16 Nov 2005 10:07:23 -0600
> Received: from willie.baylor.edu ([129.62.8.12]) by waylon.baylor.edu
> Wed, 16 Nov 2005 10:07:22 -0600
> Received: from mail131.pi.net.pl ([195.116.221.99])
> by willie.baylor.edu (SMSSMTP 4.0.5.66) with SMTP id
> M2005111610072132326
> for <GRASSLIST at baylor.edu>; Wed, 16 Nov 2005 10:07:22 -0600
> Received: (qmail 10117 invoked from network); 16 Nov 2005 16:07:21 -0000
> Received: from unknown (HELO sorbus) (werchowyna at 83.27.0.201)
> by 195.205.153.131 with SMTP; 16 Nov 2005 16:07:20 -0000
> Subject: Re: [GRASSLIST:9088] Re: missing Freetype includes - can't
> build
> cvs 15.11.2005, 23:15
> From: Maciek Sieczka <werchowyna at epf.pl>
> To: GRASSLIST at baylor.edu
> Cc: Hamish <hamish_nospam at yahoo.com>,
> David Finlayson <david.p.finlayson at gmail.com>
> In-Reply-To: <20051116143235.5039ab98.hamish_nospam at yahoo.com>
> References: <1132094353.25818.3.camel at localhost.localdomain>
> <be6d1720511151513h5b6e9ees494246f72bed73d5 at mail.gmail.com>
> Content-Type: text/plain
> Date: Wed, 16 Nov 2005 17:07:30 +0100
> Message-Id: <1132157250.26917.43.camel at localhost.localdomain>
> Mime-Version: 1.0
> X-Mailer: Evolution 2.2.1.1
> Content-Transfer-Encoding: 7bit
> X-OriginalArrivalTime: 16 Nov 2005 16:07:22.0886 (UTC)
> FILETIME=[D42A4A60:01C5EAC7]
> W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.epf.pl/
