[GRASSLIST:9204] Re: problems importing ascii files
    Massimiliano Cannata
    massimiliano.cannata at supsi.ch
    Wed Nov 23 12:08:24 EST 2005
Are you sure your region include the points?
Try "g.region vect = yourvect"
and d.vect yourvect
Nothing appears?
Marco Rigotti wrote:
> hello,
> I had difficulties both with "r.in.arc" and "r.in.gdal". To be honest,
> I succedeed in importing my "files.asc", having no errors or warning
> messages. Then the problem came: I added the imported files in my
> workspace, I started a display(x0), I used the button "display
> selected layers (current region)", but nothing appeared on the
> display. I see my computer is working when I give the command to
> display, but then it seems as if nothing happened.
> I know it should be quite a silly issue, but actually I can't guess
> what the problem is. Is there anyone who have suggestions!!
> thanks in advance!!!
> Marco
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
