[GRASSLIST:9219] Re: newbie questions DEM v.in.org
ivan marchesini marchesini at unipg.it
Fri Nov 25 09:34:33 EST 2005
v.what.vect
using this command you can see the attribute table simply using the
mouse....
but there are other ways, as
db.describe
that can be used to see the column of the table, and so on...
Il giorno ven, 25-11-2005 alle 09:36 -0500, Travis Kirstine GIS Tech ha
scritto:
> Hi
> I have some basic questions about importing, viewing data.  I've been a ESRI
> user for a few years and would really like to start converting much of my
> work to Grass especially surface analysis.  Right now I'm trying to import
> shapefiles (contours with elevations stored in 'contour' field in the
> shapefile's dbf) to use to create raster surfaces.  First I import the
> shapefile with v.in.org and select -z 'Create 3d output'.  Then try to
> convert the contours to a surface using v.surf.rst but I get an error
> because is unable to locate the z values in the attribute table.  How do I
> view attributes associated with a vector file?
> Travis Kirstine
> First Base Solutions Limited
> 140 Renfrew Dr, Suite 100
> Markham ON
> L3R 6B3
> Phone 905.477.3600
> Fax 905.477.3882
> tkirstine at jdbarnes.com
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
