[GRASSLIST:9251] Re: mapping the output of a population model
Luigi Ponti
lponti at infinito.it
Tue Nov 29 16:11:26 EST 2005
Thanks Ian,
I used it and it worked very well. I also used only the r.mapcalc to
clip instead of MASK, so as to clip just one layer and not the entire
display.
I would like to ask if somebody knows the reason why when saving a
display to a .png file with d.out.png, the legend produced via d.legend
does not show up in the saved .png image.
As a side note, I would like to thank again the mailing: my mapping task
is pretty much accomplished.
Luigi
Ian MacMillan wrote:
> Luigi, try something like:
> r.mapcalc newmap= 'if (oldmap>1000,oldmap,null())'
> -Ian
> On Nov 28, 2005, at 1:48 PM, Luigi Ponti wrote:
>> Thanks Stephan,
>> I was able to import the ASCII text file to vector points and
>> interpolate between them.
>> Also, based on a very useful but unrelated discussion, I obtained a
>> very pretty shaded relief over which I draped the interpolated raster.
>> Now I have started clipping the region that are not of interest to
>> the analysis. To clip out what is not California, I have transformed
>> a vector layout of the state to a raster via v.to.rast, and used it
>> as a mask in v.surf.rst.
>> How could I clip regions that have an elevation greater than a
>> particular value based on the elevation model raster?
>> Thanks again,
>> Luigi
>> Stephan Holl wrote:
>>> Hello Luigi,
>>> On Mon, 21 Nov 2005 17:20:05 -0800 Luigi Ponti <lponti at infinito.it>
>>> wrote:
>>>> Thanks Ian and Hamish,
>>>> I was eventually able to fix the problem by downloading a
>>>> unprojected California layout shapefile (form <www.census.gov>) and
>>>> then
>>>> importing it via v.proj in the location with the digital elevation
>>>> map. Apparently the official shapefile of California layout has a
>>>> wrong latitude.
>>>> Next step is to connect the output table of the population model
>>>> (population densities at weather stations) to the map I have just
>>>> created. This would hopefully result in an interpolated raster.
>>>> Hamish suggested the following:
>>>> Load in site data with v.in.ascii & interpolate between sites with
>>>> v.surf.rst.
>>>> According to the manual v.in.ascii uses the | separator. Is it worth
>>>> to manually put the file in that format or do you think is better to
>>>> convert it in a database to connect with a specific command?
>>> you could use the fs="," for selecting a , as a selector.
>>> have a look at the manual-page of v.in.ascii.
>>> g.manual v.in.ascii or
>>> v.in.ascii -h
>>> Best
>>> Stephan
> What happens if a big asteroid hits Earth? Judging from realistic
> simulations involving a sledge hammer and a common laboratory frog, we
> can assume it will be pretty bad.
> - Dave Barry
> This message has been scanned by Postini anti-virus software.
