[GRASSLIST:8489] Re: setting region resolution
Markus Neteler
neteler at itc.it
Tue Oct 4 14:53:42 EDT 2005
On Tue, Oct 04, 2005 at 01:40:25PM -0400, Jason Horn wrote:
> Does anyone know why, when you set the resolution of a region, you
> end up getting a resolution slightly different than what you
> expected? For example, in a lambert projection, if I set the
> resolution as follows:
> g.region nsres=1000 ewres=1000
> and then I query the region settings...
> g.region -p
> I get this
> nsres: 999.51820128
> ewres: 1000.27989946
Try the -a adjustment:
g.region nsres=1000 ewres=1000 -a
(it's a feature, not a bug)
Markus
